Bizhub Pro920 SC67-09, not in the manual.
  • bubblegoose72
    • Jun 2008
    • 49
    Seems to be in the DF, and the only way to get around it is to open the DF top cover when you power up. The machine will come to ready, and then you can close the cover and move on. Problem is that the code is pretty persistent.
  • tech51
    • 846
    Had the same thing on a 1050 DF the other day, it turned out to be a dirty reflector for one of the sensors. I know its not exactly the same feeder but I would definately clean all the sensors/reflectors and readjust them just to be sure.
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Odd...
      Not at all in the manual.
      You saw this personally? Or was it relayed to you via customer?
      A TSB for that machine relates to sensors on the closest error I could find.
      Solution ID TAUS0801372EN* Solution Usage
      Description
      SC67-03 only when the DF-606 is lowered when powering on the machine.If the document feeder is left in the raised position and the machine is poweredON, the machine works properly.
      Solution
      CAUSE: Possible "dirty" RADF photosensors.
      SOLUTION: Inspect and clean all of the RADF photosensors. They may be causing this
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
