you might want to check the black inversion assembly attached to the top of the door and make sure that isn't broken. also check the operation of the motor that drives the exit gears. rb
Haven't worked on one for a while but I seem to remember that the exit sensor actuator can stick in the up position causing a phantom jam. When the side door is opened to look for the paper, the actuator drops back into its normal position allowing the code to clear. It used to happen on older machines when the door support frames got a bit bent out of shape.
