HDD data now clear
  • poz31
    • Aug 2006
    • 86
    HDD data now clear
    But it never goes away. Tried to reset print server manually and through web tools and nothing.
    The problem the printer will not work. Is there a way to clear data on the HDD?
  • ebm
    • Apr 2007
    • 183
    HD-105 is no good. Call a tech to replace or remove it from the main body. You won't be able to print/scan without it.
    • poz31
      • Aug 2006
      • 86
      Thanksxxx for the response
      Actually I'm the tech, but mostly working on the bizhubs.....
      This is the only machine I got (seems the DI 551 and DI 650 are the same)
      but going back to the topic.....
      Do I need to reset the software (for the PI 6500)????
      I have set up this machine to scan to the hard drive....will formatting the HDD will fix or need to get another hard drive??
      Is there a way I can do a back up or image from the HDD installed on the di551???
      Since I only have this machine I have only the service and parts manuals..Any manual that I should get?
      • ebm
        • Apr 2007
        • 183
        With the Konica 7155 version of this engine the HD usually needed to be replaced. You can try to format the HD and reload the firmware. Sometimes that worked temporarily, but usually got a recall and had to replace.
        • poz31
          • Aug 2006
          • 86
          OK I replaced the print controller with a different HD and nothing....
          Tried to locate the HD-105 but the parts manual or field manual does not mentioned ....only there is simms on mode 47 to check up the HD
          could you tell me where is located????
          I got a DI 650 parts machine.
          • ebm
            • Apr 2007
            • 183
            Tries to locate the HD-105 but the parts manual or field manual does not mentioned ....only there is simms on mode 47 to check up the HD
            The Hard Disk check procedure is in the 47-mode of the Adjustment Section of the Service Manual. There is also a IP connection test in the Output Checklist of the 47-mode.
            Not sure if Konica 7155/65 model options such as IP511 and HD105 is interchangeable w/ the Minolta Di551 model.
            • ebm
              • Apr 2007
              • 183
              There is two hard disks. One is the HD-105 and there is a hard disk in the print controller.
              Try checking the 25-mode soft switches and try to isolate the components to narrow down where the problem might be. If you disable the HD105 and/or print controller and the machine fires up then you know the problem is w/ that unit. I think there are switches that tell the machine the option HDD is connected and switches that will disable or isolate components for troubleshooting(paper trays,HDD,finisher,etc.).
              • poz31
                • Aug 2006
                • 86
                update.....
                Update....
                I did turn it off (HD) by means of simulation 25 switch 2....
                machine started working , printing and scans BUT..... takes a long time......
                I think somehow the disable HD is needed .... do you know where the HD is located???
                please help
                • Morlock49
                  • Mar 2009
                  • 166
                  there is a seperate hard drive for the copier, which is not part of the print controller.
                  Memory Upgrade Options
                  HDD-2 4595-611 20GB HDD Kit For storing scanned images and adding stamps/watermarks to documents
                  The hard disk will be on the back right hand side, about half way up the chassis, it will have a metal box frame with a fan on the outside at the bottom.
                  Setting the software DIP switch
                  1. Enter
                  25 mode.
                  Caution:
                  DO NOT start up from the MODE CHANGING
                  MENU.
                  2. Set DIP switches 2-0 to 1 (ON).
                  3. Check installation of the hard disk unit, following
                  the procedure below.
                  (1) Turn the main power switch OFF at the main
                  switch of the main unit, then back ON again,
                  checking to see whether or not any error indication
                  appears.
                  Caution:
                  Should an error indication appear, check to make
                  sure the DC power wiring connector and the hard
                  disk interface wiring connector of the hard disk unit
                  are firmly connected.
                  (2) Enter the Key Operator mode and select 18
                  "HDD management setting."
                  (3) Select 3
                  "State of HDD capacity" and check to
                  see whether or not the HDD capacity is indicated
                  I hope this helps
                  Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
