Minolta Di550
  • mike1025
    • 10
    Minolta Di550
    how i can turn on the scanner function on, and what is the procedure, and how i can get the scaning software, thank you
  • Scott_Lewis
    • Mar 2007
    • 519
    The scanning feature is on by default with the proper installation of one of two print controller options; the fiery Pi5500 or the Pi5501 + P.S. option. There is no 'scanning software' for the fiery (that I recall). The PageScope Cabinet comes with the controller CD package and can (with difficulty) be found on-line. Last time I found it only after an hour or so of digging into the pagescope site (I think).
    So, which print controller are you talking about?
    • tonytonytony3
      pi5501 password reset
      Can anyone instruct me how to reset the pagescope password for a Pi5501, I reset the NIC card to the factory settings and that only released the IP address, I am able to print to it now, but am not able to login to pagescope using SYSADM as that is the default password.
      • Scott_Lewis
        • Mar 2007
        • 519
        Did a hard reset?
        Did you do the reset to factory settings using the jumper on the NIC? When you do the reset, you need to let it process for a full minute according to KM.
