C220 movie data
  • Gerg?
    • Jul 2008
    • 67
    C220 movie data
    I wanted to use ID&Print function on this model. Unfortunatelly it doesn't work until you made an Initialization (clear all data). After that I had to switch on the HDD and reload Movie Data.
    I don't know how can I reload the Movie Data.
    I have movie data and I tried to reload same way as the firmware. But it doesn't work.
    It will be wonderfull, if sombody can help me.
    Thanks Gergő
  • B0265
    • Jan 2007
    • 718
    It is the same procedure as for the C652:
    http://www.copytechnet.com/forums/ko...-software.html
    • Gerg?
      • Jul 2008
      • 67
      Many thanks
      I have found it.
      Thank you again.
      • ims
        We have the same problem with the movie data, we tried to update the firmware but there is no change. The movie data is a separate file or it is in the firmware package. If it is a separate file where can I download it?
        Thanks in advance,
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          movie data files are found in the special firmware section of SSD.
          The movie data is loaded in tech rep mode, system 2, load data.
          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
          ---Groucho Marx
          Please do not PM me for questions related to Konica Minolta hardware.
          I will not answer requests or questions there.
          Please ask in the KM forum for the benefit of others to see the question and give their input.
