We seem to have a lot of these machines with squeaking iu's I have re-dusted the drums with no joy, i have also used silicone grease with not much joy. I think the noise is a vibration from the cleaning unit. is anyone else having this problem.
Konica Minolta C252
nichjar
Hi,
i had this problem at the last place i worked for, nothing seemed to fix the squeak! The only thing we could do was replace if a customer complained too much. Dont know if theres been a fix as of yet. -
IU Sqeak
Km released a buliten about the Squeaking IU's last month, the drum shaft contacts were not greased at the factory. Just peal back the label on the front of the IU remove 3 screws and the cover comes off, apply any conductive grease to the drum shaft contacts (2 contacts) reinstall the cover and press label back in place. No more squeak!Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
I will be checking the contacts on the drum shaft in future.The gene pool could use a little chlorine.Comment
C252 IU Noise is common even on new machines, especially the cornish ones
Check out this link and get the instructions PDF
Biz NVRam Repair & Technical Site provided by Bravenet.com
Speak Soon
RegardsComment
Speak Soon
RegardsThe gene pool could use a little chlorine.Comment
Speak Soon
Regards
ScottComment
