Bizhub 600 image shift
  • paulterack
    • Oct 2009
    • 12
    Gents,
    everything prints and copies just fine. The problem I'm having ONLY occurs when I'm scanning a document. The resulting scanned image has been shift to left a little MORE than a quarter of an inch. It leaves a vertical line on the right hand side of the paper which is most likely the edge of the scanned original.
    Subsequent scans can/will lead to cutting off of document information etc.
    any thoughts?
  • SmellsHot
    Head Tech
    • 512
    Sensors
    Make sure you clean your sensors in the DF. Most importantly the sensors that lay underneath the DF. Remove the black guide (3screws) and than the white guide underneath that one (2screws) Clean these sensors. I've seen this happen before
    Good luck
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • KEVIN900
      Copier Ninja
      • Oct 2009
      • 200
      Hey paulterak, If you check the List of Adjustment Items (section 9) of your feild service Manual, you'll find separate adjustments for Printer area and scanner areas. They are adjusted independantly of each other. I had this problem on a Biz200 a while ago, and it took the customer to show me on her computer screen for me to understand the issue. Good luck.
      Kevin900
