Konica BizHub 500
  • jdefrehn
    • Aug 2025
    Konica BizHub 500
    We have a 500 in our office. I am racking my brain to try and answer this simple question:
    Is there a way to set the BizHub to only scan into PDF? Right now we have TIFF and PDF as options, but I only need PDF to be up there. Any help or suggestions would be very much appreciated. I have not been able to find a switch or option for it in the web interface.
    Thanks - J
  • mrwho
    Major Asshole!
    • 4299
    As far as I know you can't "hide" the TIFF option. You can instead put PDF by default, though, if I'm not mistaken. Is that it?
    Mascan42
    Ibid
    • jdefrehn
      That would work as well. I can't find a way to do that from the web interface. Would it need to be set up directly on the printer's touch screen interface?
      • mrwho
        Major Asshole!
        • 4299
        Yes, although I'm not sure how it's done - it's been some time since I serviced one of those.
        Try the following at the machine:
        - Change to the Scan screen;
        - Configure all the options the way you want them to stay (file format, resolution, etc);
        - Enter Utility Mode (Utility button);
        - Enter User Setting
        - Enter Initial Setting
        - You should have the option to use the Current Settings as default.
        If it doesn't work, I apologize - I'm typing this from memory. Maybe someone else can help you better.
        Mascan42
        Ibid
        • mrwho
          Major Asshole!
          • 4299
          Just found this:
          DESCRIPTION: How to set default file type to PDF or TIFF in Scan mode.
          SOLUTION: To set the default file type, perform the following:
          1. Press [Scan] and change the file type from [TIFF] to [PDF] on the operation touch panel.
          2. Select [Utility/Counter] -> [User Setting] -> [Initial Setting]. Change from [Factory Default] to [Current Setting] and press OK.
          3. Return to the basic screen.
          Seems like I wasn't too far off.
          Mascan42
          Ibid
          • jdefrehn
            Awesome sir. You have been a huge help. Thanks so much for your time and knowledge.
            • mrwho
              Major Asshole!
              • 4299
              You're welcome!
              Mascan42
              Ibid
