di 7210 adf jams at intake
  • krm
    • Aug 2009
    • 233
    I cleaned all one way bearings and replaced feed and pick up rollers. I cleaned rear one way bearing on secondary feed as well. It makes a binding noise and locks up at feed rollers.
    Any ideas?
  • SmellsHot
    Head Tech
    • 512
    If this is similiar to the konica 7255/7272 .....than try this.....open df cover....than lift up metal lifting plate(have to bend a lil piece of plastic to get plate up) with plate lifted there will be 3 gears.....than tend to get a lot of build up in between the teeth! I hope this helps.......and I hope they are the same DF!! haha
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • krm
      • Aug 2009
      • 233
      Thanks, I have had noise problems here, but not jams, I will check them.
      • Kmdurrin
        Copy/Print/Network Tech
        • Dec 2008
        • 132
        I would check the clutches as well. Had a Di5510 with a similar problem recently.
        Parts: Its what your copier craves!
        • Rudi
          • Jun 2007
          • 251
          There is a torque limiter on the unit that gave me a similar problem , cleaning the one way bearings didnt help but replacing them did.
