Bizhub C350 Colour Problem
  • connecticcut
    • Feb 2010
    • 53
    #16
    you empty the developer by the entry toner (you don't need tool).Vous fill a bag in 30 seconds (if you prefer plastic bottle,no problem).You have developper for Cf3102,C350 and 351 (same developper).
    When you have white lines ,you add developper (not a big quantity ) and you don't change IU (for long time)
    • don
      #17
      Dear Friend,
      Don't replace with new one. If you have old used Cyan IU then remove the Developer powder from it and fill it in the current one. shake it gently and fix it . Do a TCR toner supply in it.
      Try printing Halftone and check the quality. I hope this will work. I have done this with my machine. Working fine.
      Thank you..
      • Eddie
        • Jun 2009
        • 31
        #18
        re:Bizhub C350 Color Prolem
        Replace the cyan image unit
        • fishleg
          • Mar 2009
          • 426
          #19
          How can you tell how good the developer is by looking at it ? How different can dev actually be between machines ?
          Is it true as it comes to end of its life it no longer holds the toner properly and just spits it out the dev unit ? I've seen dev become like clumpy and stick together but these colour machines how can you tell if its worth saving for a rainy day ?
          Cheers,
          Fishy
          • connecticcut
            • Feb 2010
            • 53
            #20
            no problem for me...
            You choose .....add dev is free or you replace I.U and you pay 300$ (i have never problem when i add dev...I have a good quality for a long time)
            try...it is free
            • shark66
              • Nov 2009
              • 6
              #21
              I tried it today with a bad magenta C450 IU and it worked perfect.
              thanks
