Konica 7020 - error j-81-0
  • manuela
    • May 2025
    Hallo, i have a problem with a konika 7020 copier, tell me there's an error (J-81-0), but there's no paper in the machine, what can i do?
    thank you
    bye
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Description
    J81-0 at power up.
    CAUSE: Dirty or failed PS1 (registration PS).
    SOLUTION: To check PS1 for proper operation, perform the following:
    1. Power the copier OFF.
    2. Access the 47 multimode (power the copier ON, while pressing the 4 and 7 keys) input code 20, *-001-*.
    3. Actuate PS1 (registration PS) to see a change of state on the touchscreen.
    4. If no change of state occurs clean or replace PS1 (p/n 552085510) as necessary.
    5. Power the copier OFF/ON to exit the 25 mode.
    Hope this helps
    Parts: Its what your copier craves!
    • manuela
      ThankS!
      Thank you so much, but i'm not a really technichan so i don't understand the commad like 25 mode...can you please tell me what i have to do with a simple mode?
      thank you
      bye
      manu
      • Kmdurrin
        • Dec 2008
        • 132
        In that case... I would recommend that you call a tech. Dont start messing with the machine if you dont know what you're doing, unless you want to risk causing a more serious problem.
        • manuela
          ok
          I call the tech, thank foryour help again!
