Darren
  • darrengal8
    • Aug 2025
    Darren
    Hi
    I'm getting CFB55,CFB56, CFB57, CFB58 error codes intermitely on a bizhub c250 (MFP Control Board/Engine) i have reset these now but log shows that these have been reset about 10 times in the last week. machine seems ok now have run of about 50 prints. does anybody have an idea what they mean.
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    MFPB failure.
    Likely needs to be replaced.
    Try reseating all the cards and such on the board, but I doubt this will help
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • Kmdurrin
      Copy/Print/Network Tech
      • Dec 2008
      • 132
      CFB55 indicates a problem with your NVRAM chip. Are you a KMBS tech?
      Parts: Its what your copier craves!
      • darrengal8
        Darren
        Hi
        Yes i am a minolta service engineer
        • Stirton.M
          • Oct 2009
          • 1804
          try swapping NVRAM with another machine and see if the problem follows to that machine and vice versa.
          Failing that, try doing an NVRAM restore (via special firmware you can download from mykonicaminolta). I do however recommend that before you do this to generate a service ticket with Tech Support regarding this. They will likely direct you to do this, but it helps getting the event recorded before you make the attempt. If NVRAM is completely toasted, you will have to have it replaced, and Tech Support records can get this ball rolling.
          ---Groucho Marx
