Hello. I am having a problem with a C450 copier, as it gives C5370 error code. As I saw in SM it is a fan code located in the back of the copier, on the steel cover of the mainboard. When I turn on the copier it doesn`t warms up at all no fans running or anything ... and you cand barely see on the display of the copier the error code ... also the display switchon has no effect ... i`ve checked the fan i was talking about and it is working on a 5V power supply, i`ve checked all the fuses that i know and none of them are burned. My questions are: Can there be another fan for this error code?; Or is there anything commanding the fan that might have problems ... like a fuse that i coudn`t find or something else?
Thank you!
Thank you!
