Bizhub c652 fiery ic412
  • big jase
    • Jul 2008
    • 136
    i have a couple of machines that has lost the finisher on pc driver, i can configure that the finisher and lct or fitted but then when two way communication is activated it loses the finisher options. the only way i can cure as a stop gap is to shut down the fiery .this works for a while but then drops the options again.
    If at First you don't succeed remove all evidence of ever trying!
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Check the VIF card itself for secure seating inside the machine. Check the cables as well.
    Also, ensure firmware is up to date on the copier, along with system code of the Fiery.
    The following tsbs may apply to your problem...
    Adobe - Adobe Reader download - All versions
    Latest system code is version 1.1 along with several patches and latest ROM for copier is A100-G00-06, released yesterday as a matter of fact.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • big jase
      • Jul 2008
      • 136
      thanks Stirton.M, i did install the patch you mentioned on install of machines. that new firmware may help
