Konica Minolta 5510, #1 tray won't lift
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    The machine knows if the tray is open or closed, I checked for paper jammed in the plug. I also swapped the feed assembly. When shut the tray does not try to lift, it just keeps saying add paper. Any thoughts?
  • Rudi
    • Jun 2007
    • 251
    Hi fixthecopier
    Damn!! you bring back bad memories , i had the same problem on a b 600 once and the paper (a very small piece) was jammed inside the connector after all the laying down, bending down and swopping feed units i saw this piece of paper .While i was in the down position i reached for my springhook and got that mf out only to realise afterwards the machine was still on needless to say i blew the control board. Sorry for not being able to help but i just needed to get this of my chest.
    Regards
    Rudi
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      I have a gut feeling about that plug, the one on the machine body is clean and I can't feel anything in the tray side but I can't see it. I'll tak a mirror in tomorrow and look.
      • manuelcorrea
        • May 2009
        • 46
        have you tried lift motor? part #4024-2076-01
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Check plug again today, I guess I will try a motor on Monday
          • brent
            • Nov 2008
            • 1213
            the only luck I had was the paper lift motor. not too hard to change out.
            brent
