i have a c3b02 code on this model , i suspect to ih power unit board, but just what see if anyone knows this fault before ordering up board
bizhub c652
"Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
My trouble is, I've put a new fuse in there and now whenever I turn on the machine, the customer's surge protector (I'm not sure if this is the correct name, I'm talking about the set of switches at the facility's power box) turns off.
I'm going to try and check if I can experiment on another outlet.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
Same results on another completely different power outlet. Going to take out IHPU board and check everything.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
Well, so far it only happens if the 5-pin connector at the top right of the IHPU is connected - so I think I can rule out the PSU, the IHPU and the heating coils.
On the other hand, now I'm completely puzzled, since I don't know what the heck is going on with this machine!
Help!' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
Hold on to that last post - I've tried it now with the 5-pin connector connected and the coils disconnected and the problem also didn't turn up.
It all points now to the coils - I'm going to order them and see what happens.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
Now I notice I never gave any feedback on my situation - we also solved it by replacing both the IHPU and the Coil. We considered trying just the IHPU, but we didn't want to risk burning a new board with the old coil.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
Mascan42
Ibid
I changed an I.H. board on one of these this morning ,following a power cut,solved prblem staight away. this is the fourth I H board ive changed in 12 months an never had a failed coil yet, once it was the fuser unit as well. happy copying peterComment
