trouble copying in bizhub 420
  • aleksander
    • 378
    If I used small original, lets say in A6 or name card using original glass. And I used paper A4 size in tray 1 or 2. But the copy output placed in the middle of the A4 paper, like this.
    Anyone know the solution?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Did you override the auto paper selection?
    • aleksander
      • 378
      I tried using autopaper selection and manual selection, but the result is same. Anything else?
      No problem with another bizhub 420. I have 2 bizhub 420 with the same problem.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Did you initialize the non-image area on the glass in service mode?
        Is the center application turned on and set as on as a default?
        • aleksander
          • 378
          Thank you. I'll try your solution. If it still fail, i'll tell you.
          • aleksander
            • 378
            No center application turned on. Shall I adjust the non-image area on a glass in service mode? what for?
            Thank you.
