C2557 on bizhub 250
  • aleksander
    • 378
    ok
    • connecticcut
      • Feb 2010
      • 53
      for DI2510 = ATDC value is 155
      for BIZ250 = ATDC value is 165-170
      when you reset the drum on Biz250, it appears an error code (C2557). To avoid this, given that the drum may work even 30,000 copies, you decrease ATDC 5 and you do F8..La new value (ATDC) decreases troo many.You increase it by step to have a minimum value of 135..The copies will not become dirty after a hundred copies.You can not directly change and you are obliged to do so by step (value increased by 10% else C2557))
      for your problem, do you try F8
      it's easy for me to write in french,but in english is different...sorry
      • Hansoon
        • Sep 2007
        • 3402
        for DI2510 = ATDC normal value is 155
        for BIZ250 = ATDC normal value is 165-170
        when i reset drum counter (only BIZ250),you have an error code C2557 (maximal,after 47 copies).You reset counter drum (when you reset the drum ,it work during maximal=30 000 copies). After,don't forget to decrease ATDC value (maximal =5) and you make F8 (machine accept without message c2557 (because you change ATDC value before F8(it's very important)).Then you have ATDC value not very good ( value=119 for ex).You add less10% (119 is replace by 125).You make 50 copies (or 25 cop double side) and you continue for to have a minimal value =135. (else the copies become dirty after 100 copies)
        for your problem, ATDC value is may be too limit (increase the value)
        I'll be damned when I understand this....
        Hans
        • aleksander
          • 378
          #19
          No problem buddy. It's useful for me. I'm Indonesian, not speaking english. but I know what you mean. Thank you.
