Minolta Di550 C0009
  • xcopytech
    • Aug 2006
    • 1794
    Minolta Di550 C0009
    Hi,
    I have Minolta Di550 which have code C0009. I can not find such code in service manual.
    Machine come to ready and when try to make a copies just copy 2-3 pages and then copies become light and declare c0009.
    Thanks.
  • Luther
    • May 2006
    • 682
    Are you sure the code isn't c0090? developer drive moter failure? you can go into tech rep mode and under counters select "trouble" and it will show the list of the codes and a short expanation of them and if the code c0009 is correct it will be listed there
