Forgot Password
  • blue cat
    Guest replied
    Thanks guys I tried all of those and it still doesnt work. I called again and they said it should be "12345678" which it isnt. I can set this up if I could only get in. I will keep you informed and thanks again.
  • Scott_Lewis
    replied
    Originally posted by RockETop
    Isn't networking setup in Key-op mode?
    It is, under the administrator key which requires a password. I just worked on the C550 for the first time, today. The password for the web admin login is '12345678'. So, I would imagine the utility mode admin login is the same. [Just checked, 12345678 is the default pw.
  • RockETop
    replied
  • dbrownlee
    replied
    Thought default password was eight 0's, or maybe sysadm?
  • blue cat
    Guest started a topic Forgot Password
    Forgot Password
    I just got a c550 and I dont know the admin password. The place I got it from said it should be "12345678" but it doesnt work. I read on here about tech rep mode. How do I get into that on this machine? I need to setup the network because the supplier didnt setup anything.
