bizhub 420 (again). Help...
  • aleksander
    • 378
    #16
    Originally posted by stevelz
    The reason it worked one week and not the next may be the diffrence in the file size. The copier can do both but limitly. if you have too much data being sent to it and not enough memory then it will lock. Thats why adding a hard drive to the copier takes care of the problem. The copier then will have enough room to store and spool the copy job and the print job at once.
    Good Luck!
    Thank you
