c-203
  • hodgiepodgie
    • 284
    c-203
    how do i get into service mode and or reset password.is it same as nec 25c5 copier.how can i obtain a crossover chart for nec .bizhub etc
  • bizhub1
    • Sep 2008
    • 230
    To get in to service mode on these models, you hit -utility,meter count, details, stop 0,0, stop 0,1. Are you talking about the admin password you want to reset?
    • hodgiepodgie
      • 284
      well service mode to replace image transfer belt. i am trained on the nec 25c5.when i tried to get into service mode the copier sked for password.
      • tech51
        • 846
        If your just replacing the transfer belt you don't need service mode, it will re set automatically. However if you need to access service mode try this--
        Description
        How to access Service Mode when unable to use the normal procedure.
        Solution
        Service Mode can be accessed through the Trouble Reset screen using the below procedure: 1. TurnON the main power switch while holding the
        UTILITY/COUNTER key.
        2.When TROUBLE RESET appears on the touchscreen press STOP, 0, 0, STOP, 0, 1.
        3.If prompted for a password enter 92729272 andtouch END. Hope this helps..
