Can anyone help, i have several machines where the fiery locks up on certain jobs (all different applications) all you can do is restart fiery. customer not too happy as happening most days
ic 412 on c652
You can try doing a server clear. Like any computer, the fiery is an OS with a hard drive, and files get written to it and deleted over time, eventually the drive becomes heavily fragmented and can cause issues, especially if the queue is a large one or you have many files in the hold queue. The clear server command, available from the control interface or Command Workstation, simply deletes the contents of those queues.
Or, you can do a factory reset from the control panel only. Be sure to print out a configuration sheet before you do. Factory reset will clear the server and reset all the settings, requiring you to reprogram in those settings.
The previous guys also mentioned what version you are running, as well as applicable patches needed. Current version of fiery system code are 1.0 and 1.1, each has a series of patches.
You can access the device remote desktop via another computer on the same network. Use the remote desktop link found in the start menu, provide the IP address of the fiery and when prompted, the login name is Administrator and the password is "Fiery.1" without the quotes. From there, you will see an XP desktop. In the start menu, you will see the Fiery Tools, select update...the rest should be obvious to do this.
Also, ensure the copier has the latest firmware. Base firmware is G00-06.
Also, ensure your client is using the correct driver for the system version level of the fiery. To be sure, only download the driver that is available through the Fiery Web interface itself, not off the net. The CD package may or may not have the correct version as well."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
