Scan to ftp on Bizhub250/350 and c200
  • desmond
    Hey guys,can you kindly explain step by step how to setup scan to ftp on these two particular models. We are in Botswana and the one mail server is sitting in China and the other in Italy. Plis advice a. s. a . p
  • harry2007
    • 52
    You don't need mail server for FTP scaning. First install "konicaminolta ftp utility" (find it with google) on computer where you work with scaned images, and run it.
    Second, with a internet browser ,type in adress bar the IP of your copier. In this interface , in "Scan" create "one touch destination" (PC or FTP- anonymous) .This one touch will be find in scan tab on the copier.Select it , and press Start on the copier for scaning documents .( but take care-the most firewalls block 21 port-FTP port, so unblock this port or suspend firewall for scaning period).
    http://copierservicereset.com
    • aleksander
      • 378
      You don't need mail server for scan to ftp. Just install FTP utility. Open the bizhub 350/250 web connection using web browser. Fill the one-touch address, Ip address, directory etc. After installing the FTP utility, run the FTP utility. For FTP utility setting you can browse to your FTP folder. Beware with your firewall, unblock your port 21 or you can make exception for your windows firewall.
      I hope it will solve your problem.
      • sparkin19
        If all else fails, use Box Operator.......Hahaha
        • Hansoon
          • Sep 2007
          • 3385
          Minolta's FTP Utility will not work with Vista or W7. Here's a very good free alternative:
          Quick 'n Easy FTP Server Lite
          Hans
          • jiss
            Ezy-FTP 2.43
            Hi,Tryin to make work a little easier?. Download - Ezy-FTP 2.43
