Imaging Unit K - image quality problem
  • billak
    • Mar 2010
    • 5
    #16
    The cause is IU all the way. Black IU is complex and heavy and sometimes it gets damaged while transported. The problem is the distance between developer brush and drum gets uneven in front or sometimes in back side. Causing developer brush and drum to contact each other. Then developer splits. Just replacing the IU will solve the problem.
    • tech51
      • 846
      #17
      Definately faulty IU and loss of bias contact at the rear of the unit as per my previous post. Latest info is that the K IU`s have been modified in production since Feb 2010 (look for a green dot next to the lot number) and a proper locking bracket is going to be fitted to stop the IU`s moving forward in use. Lets see if this is a fix...
      The P14 code can normally be cured by firmware update and skew readjustment.
      • krazeekidz3
        • 48
        #18
        Hey, that's great news! Just had a call today on that same C550. Having black streaks and image offsetting. I couldn't reproduce the problem, this time. That bought me a little time! Thanks a bunch!!!
        • krazeekidz3
          • 48
          #19
          SOLUTIONS SUPPORT DIVISION
          Bulletin Number 7370
          Date:
          03/29/10
          SSD
          Subject:
          Dirty Images, Black Developer Spew - MANDATORY CHANGE
          bizhub C451:
          073 bizhub C550: 082 bizhub C650: 066
          SYMPTOM
          In some cases, prints may be either partially or completely covered by excess toner, creating a dirty
          appearance. At the same time, developer may have spewed into the machine.
          CAUSE
          Poor electrical contact of the charge terminal at the back of the IU results in improper operation of the drum
          charge control. This causes too much charge to be applied to the drum, resulting in dirty images. Poor contact
          can occur if the IU is not seated firmly and securely.
          SOLUTION
          Install a new lock plate to secure the black IU in the correct position. Fasten it with
          the existing screw that is used for the sub toner hopper as shown.
          This lock must be installed on all of the machines listed on the next page. Refer to
          the Important note on the next page.
          Page 2 of 2 Bulletin Number 7370
          CUSTOMER INSTRUCTION
          For those instances where a customer, rather than a technician, replaces the IU, you must show the customer
          how to remove and reinstall the lock plate when the replacing the IU. A magnetized screwdriver is required.
          SERIAL NUMBER INFORMATION
          Model Serial No.
          C451 All
          C550 All
          C650 All
          PARTS INFORMATION
          Description Part No.
          Lock Plate for black IU A00JP33100
          IMPORTANT: Effective March 29, 2010, warranty claims for black Imaging Units for these models will not be
          processed unless a Lock Plate has been ordered for that serial number. Determination will be made by
          comparing the Warranty Claim serial number against the shipments of Lock Plates.
          FOC PARTS ORDERING PROCEDURE
          Free-of-charge (FOC) Lock Plate p/n A00JP33100 can be ordered via the Online Technical (FOC) & Special
          Program order form, located within MyKonicaMinolta.com (Service
          โ†’ Warranty, Repair & Special Programs).
          *FOC parts for this program will be available for units that are within the affected serial number range as
          mentioned above. These FOC parts will be available from March 29, 2010 to July 31, 2010.
          Upon our receipt and verification of your online claim information, KMBS Service Operations will process a
          Free-of-Charge order. All replacements will be shipped via UPS Ground Service. As mentioned above, KMBS
          will ship all Lock Plates at no-charge. Therefore, no invoice will be generated. No defective parts are to be
          returned to KMBS for this specific FOC Program.
          Questions related to your FOC Lock Plate claims may be directed to KMBS Service Operations at (201) 934-
          5339.
          Thank you for your continued support of Konica Minolta Business Solutions, Inc. products.
          • Matt25112
            • Mar 2008
            • 38
            #20
            You have till July 31st to get these in as you see in the most important quote of this bulletin:
            "IMPORTANT: Effective March 29, 2010, warranty claims for black Imaging Units for these models will not be
            comparing the Warranty Claim serial number against the shipments of Lock Plates"
            We have ours and I am heading out to install these shortly that explains why I had enough buildup inside my c650 where it fell on the write glass.
            • Kmdurrin
              Copy/Print/Network Tech
              • Dec 2008
              • 132
              #21
              We just got done installing these mod kits on all our machines as well. Its just a little metal plate to hold the IU in place. Super easy to do.
              Parts: Its what your copier craves!
