Pro C5501 smart/ Code c-0418 x 2 machines same install
  • Si@danwood
    • Mar 2008
    • 154
    Okay New install,both machines installed with lu-202 and HT503 tray dehumidifer's upto spec with f/ware Both giving C-0418 when set for coated stock! I know there is a bulletin for this and the fix is to replace the lu control pwb with a modified type,which is fine.The question i ask is does anyone know if this is a definate fix,as machine's have only been in 24 hrs,and wanna make sure we hit them first time as customer getting a tad edgy Cheers in anticipation Si
  • kmcopier
    PSP
    • Oct 2008
    • 183
    check your LU-202/HT-503 interconnection harness to main body
    • Si@danwood
      • Mar 2008
      • 154
      Yep the dehumidefier's were both installed without the three pin ac power harness plugged in!!!! Connected up and working a treat! Thanks
