BizHub 600 Punch Kit PK-505
  • Imageer
    • Aug 2025
    I am working on a BizHub 600. The PK-505 punch kit is installed however, the copier does not recognize it. The punch is working because I can use it when printing, however the option does not exist on the copier and I cannot find how to turn it on in service mode. Does anyone know where I am going wrong here?
    Thanks.
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    You need to tell the copier that the punch kit is there. DipSwitch 26-2, set to "0". 26-3, set to "1". Also check 22-2, "0"; and 22-1 is "1". Under the black cover over the punch kit control board; adjust all the VR's, one at a time, so that the LED's turn off, then just adjust the VR's till they turn back on.
    Kevin900
    • truschi
      Re: BizHub 600 Punch Kit PK-505
      Hi,
      this settings are working for bizhub 750 - fs504 too?
      Thank you.
