I have the IP-431 board and I downloaded the PCL Drivers (IP-432 PCL Win2K XP 2003 vKM4417a.exe) from Konica website. While I am able to ping the copier and access/change settings using the PageScope Network Setup I am unable to print anything or scan to computer/ftp/email etc. It gives me an error that network connection is not available. When I go into Key Operator Mode I see the following menus:
1. System/Copier
2. Network
3. Scanner
4. Enhanced Security
Can someone please explain to me how I can connect the copier to make it print over the network and, also, scan into PDF and send it to the computer (doesn't matter is its through FTP or directly). I am just tired of trying to figure this out. Thank you.
BTW I am sure that the PCL drivers work fine since they do print when I enter a different IP number so that I can print on a different network printer (even though the text is unreadable).
1. System/Copier
2. Network
3. Scanner
