Minolta CS-PRO EP 3050, error Code: M2
  • CF_NGUYEN
    I have a photocopier Minolta CS-PRO EP 3050 which is using for the Church. Now I can not use it anymore because, when I turn it on, the digital screen appear : " Please call service professional and provide Code : M2 ".
    I would like to know if someone would help to resovel this problem such as reset the code . It had been using very good. But now suddenly appear that code then I can not use it anymore .
    Thank you for any helping
  • copierworks
    reset counter
    The error code M2 means that the machine needs to be maintenance. the only way to clear it would be to reset the counters and the service tech mode.
