F 36 1 on Konica 7022
  • claude1957
    • Mar 2010
    • 18
    Any body know about it
    tanks
    claude
  • jotunn
    • 606
    F36-1: TH1 (fixing temperature sensor 1) high temperature error. This error occurs if TH1 high temperature error signal is detected continuously for at least 1 second.
    You can try to reset this error following this procedure:
    Enter the "25" mode and set to "0" the bit 1 in DIP SW3.
    If error occurs again, check or replace TH1.
