Konica 7022 Ip 422
  • claude1957
    • Mar 2010
    • 18
    Konica 7022 Ip 422
    Looking for driver for IP 422 on Konica 7022 and ddriver for FK 102 on same machine
    thank
    claude
  • RRodgers
    • Jun 2009
    • 1947
    Have you tried Konica's site?
    kmbs.konicaminolta.us
    • jotunn
      • 618
      Links for drivers in priv message. And about driver for FK-102 option for this machine... you mean something like PC-FAX - sending faxes directly from PC through this machine? If so, there is no possibility to act as a PC-FAX by this machine and fax combination (they are too old).
      • jotunn
        • 618
        Claude, I made a huge mistake - I just realize, that PCL drivers for Konica 7022 + IP-422 have built-in something like PC-FAX, you just have to enable Fax option by:
        [Properties]->[Setup]->[Avilable options]->[Fax option]->[Add]
        Then you can just print your document, and in Properties select [Fax] tab and so on
        • claude1957
          • Mar 2010
          • 18
          Koinca 7022 Ip 422
          No problem at all any body can make a mistake the only peoples who are not making mistake are leading our country
          thanks again
          claude
          • jotunn
            • 618
            Originally posted by claude1957
            ... the only peoples who are not making mistake are leading our country
            Exactly
