minolta DiALTA Di250
  • kites182
    • Aug 2025
    my copier has an error of c0400. i don't know where's the problem. thanks for the help!!! have a nice day!
  • Scott_Lewis
    • Mar 2007
    • 519
    I want to tell you it is a scanner lamp failure. But, nowhere in my downloaded Di250 or Di251 manuals is there a mention of a C0400 code.
    • Luther
      • May 2006
      • 682
      It is an exp. lamp failure, I would clear the code with trouble reset then check to see if the lamp comes on during warmup,chances are the lamp is bad or the metal foil on the lamp has a break in it, good luck
      • kites182
        oops
        im sorry its not c0400. It's C004C. i hope i can get a reply.
        actually it's not the only code i am getting. i'm also getting a C0F32 and a C0500 code.
        hope u can help me. thanks in advance bro!!
        • kites182
          • Luther
            • May 2006
            • 682
            c004c is m5 failure to turn(ozone fan) c0032 is faulty toner density sensor,c0500 is fuser warm-up error
            • kites182
              thanks!!!
              thanks!
              • ftgsubvet
                Re: minolta DiALTA Di250
                I am getting the co500 error on a i250. Can you tell me the usual cause for this?
                Thanks in advance.
