cn3102e printer controller
+ More Options
Posts
  • mudhens1
    this feiry is installed in a konica cf2002...it's in network ok and can take print jobs just fine...i can't get it to scan to ftp server....i keep getting the "job done improperly" message...any hints on what parameters to look for that might need changed?
  • jotunn
    • 634
    1. You need to have FTP Services enabled in your controller configuration:
    Fiery setup -> [Network Setup] -> [Service Setup] -> [FTP Setup] -> [Enable FTP Services] -> [Yes]
    2. You need FTP server (I will suggest Konica Minolta FTP Utility to test)
    3. Configure One Touch button by PageScope Light:
    - open web browser
    - in address bar type IP address of your copier (it will open PageScope Light)
    - select [One Touch Key Registration] from the [Scan] tab
    - click an unregistered box (---)
    - select [Scan to FTP Server]
    * Destination Name:
    Enter the name of the one-touch key.
    * IP Address:
    Set the IP address of the FTP server.
    * User Name:
    Enter the name used to log into the FTP server.
    * Password:
    Enter the password used to log into the FTP server.
    * Directory:
    Specify the location (directory) for storing the image data on the FTP server.
    Should be set to '.' (dot) to select scan to root directory of FTP server!
    The rest of settings are not important.
    - [Apply] settings
    - close browser
    That's all, should work without problems.
