Konica 7228 copier
  • ebm
    • Apr 2007
    • 183
    Konica 7228 copier
    Anyone ever have one of these models turn off/on by itself? We've tried firmware update, no joy. We're thinking of replacing the operation panel next. Let me know if you have had this problem and what the fix was. Thanks.
  • Luther
    • May 2006
    • 682
    check the weekly timer settings it just might be programmed to turn it off and on,might be just that simple, good luck
    • CMB
      KonicaMinolta Tech.
      • Mar 2005
      • 458
      weekly timer could be the problem or the auto low power and auto shut off off set to low. check the wall outlet and make sure no short in it...........
      http://christianoutdoorsman.com/forums/
      www.lewisdigital.net
      Lewis Digital
      630-1 Capital Circle N.E. | Tallahassee, FL 32301
      Telephone: 850.222.4418
      Live such good lives among the pagans that, though they accuse you of doing wrong, they may see your good deeds and glorify God on the day he visits us. 1 Peter 2:12
      • ebm
        • Apr 2007
        • 183
        Copier turns off/on while the customer is using it to make copies. I should have mentioned this. Thanks for the input.
        • CMB
          KonicaMinolta Tech.
          • Mar 2005
          • 458
          well then. make sure firmware is up to latest levels.
          connect your meter to the wall outlet and watch it while copies are being made. does the voltage drop any at anytime?
          Lewis Digital
          • d7guitar
            • Jan 2007
            • 54
            PSU
            Possibly a Power Supply issue. Does it turn back on right after the power goes off? If so, the main control board could be losing it's power to operate. Like the other suggestions; check the power into the copier from the wall and monitor the power while in usage. If the power is okay, then look at causes of PSU, wiring to MCB from PSU or some load on the system while copying... Does it only happen when finishing?, Duplexing, etc.
            After all is said and done, More is said than done.
            • ebm
              • Apr 2007
              • 183
              Tech informed me that mgmt list shows 8023 (yes, eight thousand twenty three) E89-80 error codes. We will be replacing the SCB.
