Hey madu, slide the transfer belt out of the copier 6-8 inches, and on the far right, towards the front of the belt unit, under the sep finger bracket, is a small black plastic holder. You'll know it by the teeny-tiny phillips screw. In that plastic holder is a small fuse ( GSB8/100 ). replace the fuse, re-assemble the belt unit. Good to go.
hello kevin,
I still cant find the fuse location... can you give more information...
the fuse inside transfer belt isn't?
to make sure, we are talking about bizhub c360, yes?
