Bizhub c451
  • Copper0
    • Feb 2010
    • 6
    Bizhub c451
    Good day The start button flashes orange even in diagnostics,worked out it was the SLI pcb,now I get errors C FC31,CFC2B. Check the MFP pcb in another m/c works fine! Anyone with a solution?
  • jotunn
    • 608
    Try to perform data clear:
    [Service Mode]->[System 1]->[Initializtion]->[Data Clear]
    After data clear you have to setup again most of settings like:
    - install date
    - tel/fax number
    - HDD
    - image controller setting
    - FAX target in Marketing area
    - touch panel callibration
    - most settings in utility mode
    ... but it helps in case of C-FC2B error in Bizhub C253.
    • Aiwe
      - install date
      - tel/fax number
      - HDD
      Can You tell me what this C-FC2B error code means? I have this code when trying to print something time to time at the moment when the paper starts to feed from the tray on ineo+ 203.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        the code translates to
        ASIC117 first sheet unknown marker detected at JBIG core
        Dunno specifically what that means...the manual is not very forthcoming on details.
        Suffice it to say, it is related to the MFP....likely memory...NVRAM...combination of both...corrupted hard disk?
        ---Groucho Marx
        • jotunn
          • 608
          Description in service manual:
          C-FC2B ASIC117 first sheet unknown marker detected at JBIG core
          Related part: MFP-B
          So this means nothing really useful, it is just an error during decompression of the first page from job.
          It may be faulty MFP board in the copier (worst), firmware problem, network related problem or broken printer driver.
          • jma676
            Expert Tech
            • Mar 2009
            • 323
            Bizhub C451 Error : CFC31 CFC2B
            Data Flow:
            "Input buffer memory>JBIG compression>DRAM/HDD>JBIG expansion>Memory access coordinator."
            HDD/RAM/MFP Board : Error
            Error
            CFC31: MFPB failure.
            CFC2B: A failed or corrupted hard drive/Failed memory modules/Loose or damaged HDD cable.
            application-specific integrated circuit (ASIC)
            *Joint Bi-level Image Experts Group
            (JBIG) : "is a lossless image compression".
            • Aiwe
              ineo+ 203 CFC2B
              Thank you for replies. I think in my case it might be due to old firmware because it prints and this error is sporadical. I've got a new firmware, so I'll update it. Or better will call service. :/
              • habik
                • 2013
                Re: Bizhub c451
                Data Flow:
                Error
                Failed Memory module in my case on C203.
                Thanks for the info, I know its a old thread, just glad we have it on Copytechnet!
                Firmwares HERE
                • Aiwe
                  Re: Bizhub c451
                  Originally posted by habik
                  Failed Memory module in my case on C203. Thanks for the info, I know its a old thread, just glad we have it on Copytechnet!
                  I confirm that, I also had failed memory module, which was replaced by Minolta service, now it prints like a charm.
