bh500 not receive fax
  • tonycalamaro
    • Sep 2025
    FK-502 I installed, I regularly send faxes but not receive them.
    When a fax comes in, although the phone line is set as auto-rx, the fax board cut off communication.
    Could you help thanks
  • mo0651
    • 1054
    Does it have a hard drive? it may need reformatted. All setup procedures correct and in order? Check marketing area.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      This is a symptom of a bad phone line, unplug the line from your machine and call your fax number if it still rings once and cuts off, contact your phone service provider.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • emujo
        • Jun 2009
        • 3009
        A couple of ideas to try (although dialing your own phone can resolve many issues)..
        Ensure you are using the 2 wire cable supplied with the fax kit, normal 4 wire cable can cause issues
        MFP requires an analog phone jack and should not be shared with the credit card machine
        No VOIP
        Reduce the comm speed and see if any change
        If it's a new fax board in an older 500, update firmware to ver 3.0 (reload of f/w might be a good idea anyway)
        Hope you get this resolved. Emujo
        • tonycalamaro
          Thanks to your advice I have solved the problem (the country of installation was JAPAN ). Now work fine.
          thanks again
          • tonycalamaro
            thanks again
