Anyone recall what the default admin code for the bizhub c250 is? Also if it has been changed is there any way to reset it or get it back. I can't seem to remember.
bizhub c250 admin code
gabski
Hi,
You can also access the service mode by turning the machine off at the keypad then the main power switch behind the front door.
then...
turn on the keypad switch
hold utility counter button
turn on the main power switch
a black dot will appear on the screen
after that there will be an option for system error clear
at that point press stop 0 0 stop 0 1
enter 92729272 and the service mode will be diplayed. you can change the admin password in there.
if that doesnt work you will need to re-set the nvramComment
The admin code can be reset in tech rep, security mode "stop - zero - clear""Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
