SC53-18 on bizhub 1050 e
  • printsibiu
    • Aug 2025
    Hello
    I am a service technician on the bizhub PRO 1050 and can you turn it gives me error SC53-18.I have read in service manual and it tells me The fall-off of the erase lamp (EL)
    CN is detected. When turning ON
    The Power, an error detection signal
    (fall-off) is detected the specified
    period of time after the fall-off
    detection control signal of the CN EL lamp turns ON.Erase (EL), I can give anyone a solution is urgently for me
  • oscar
    • May 2010
    • 45
    Re: SC53-18 on bizhub 1050 e
    Hello, can be opened in any ICP card Printer Control Board (PRCB). ICPs test to check.
    • copy2u4u
      • Aug 2011
      • 3
      The SC53-18 is consistent with the wire on the main charge unplugged/damaged or the lamp being bad...
