konica minolta di 250
  • kites182
    • Aug 2025
    we have just delivered our konica minolta di250 to our branch but when it arrived there it has an error code of C0f32. please help me with this. THANKS!!!
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    Does the machine have a finisher? If so, it could be the horizontal transport near the fuser - the part that moves up and down when duplexing. Check that it is adjusted properly, etc.
    If you are hitting your head up against a wall it always feels better when you stop.
    • KHAN
      • Aug 2006
      • 261
      di 250
      CHECK THE DEVELOPER OR STATER , RUN F8 MODE
      IF THERE IS DEVELOPER IN THE TANK RUN F8, IF IT IS LESS REPLACE IT WITH NEW ONE AND THEN RUN F8.
      SERVICE MODE ?
      PRESS
      1, METER COUNT
      2, STOP+0+stop+1 OR stop+0+0+stop+1
      then press 1 you will see F then press 8 and start it will take 5 min
      • wagon
        Village Idiot
        • Dec 2006
        • 654
        Ah yes - the error I was thinking was cob0f
        • Rudi
          • Jun 2007
          • 251
          di 250
          To run f8 press utility, meter count ,stop 00 stop 01, select function then select f8.
          • mlombardo
            HELP
            I need help with an error code on a Konica 7145 F-51-6
            Can find service manuel.
            • copyguy5
              Konica 7145 Manuals
              Your manuals can be found at:
              Index of /protectedmembers/111514/Konica7145manuals
              I happened to find your request hidden in a DI250 thread.
              Hope this helps.
              COPYGUY5
