Di 470 MINOLTA
  • KHAN
    • Aug 2006
    • 261
    Di 470 MINOLTA
    Hi,
    TWO MONTHS AGO I REPLACE DRUM,BLADE AND DEVELOPER IN THE Di 470 COPIER, AFTER MAKING 10000 COPIES I GET COPY WITH BACK GROUND LIKE BOIS BROBLUM, I CHECKED EVERY THING BUT VAIN,THEN I PUT THE OLD DRUM IN THE COPIER IT WORKS GOOD,
    THEN I TRY THE NEW DRUM AN OTHER COPIER THERE ALSO I GET THE SAME RESULT WITH DARK BACK GROUND,THIS A OPC DRUM I CHANGE THE VG VALUE AND ATDC ,REFINE ,BUT STILL WITH DARK BACK GROUND. SO I NEED ANY SUGGESTION ?
    THANKS,
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    Sounds like it is overtoning! Set the toner level lower (can't remember how-sorry!) and run some skyshots to drop the toner level to what you like. Then redo the ATDC setup. Maybe clean the AIDC sensor too - F5?
    Hope this helps.
    If you are hitting your head up against a wall it always feels better when you stop.
    • KHAN
      • Aug 2006
      • 261
      Di 470
      thanks For Reply,i Already Did This F5 And F8 And Clean The Atdc Sensor Also. When I Put The Old Drum The Result Comes Good But With New Drum It Give Copy With Back Ground.
      • wagon
        Village Idiot
        • Dec 2006
        • 654
        OK... Have you checked the drum earth? Also, the bias pin on the mag roller (check contact in machine body is clean and check pin for wear).. I still think it might be overtoning. What are the heavy solids like?
        • Scott_Lewis
          • Mar 2007
          • 519
          Where did you get the new drum? Is it a real Minolta drum or an after market drum? You might try increasing the charge voltage and/or the bias voltage for the background.
