Konica 8031 Consumables replaced, still showing "end of life"
  • sbarnette
    • Jul 2025
    Our old 8031 went down for two consumable items:
    Transfer Roller (Life Limit)
    Paper Dust Remover/Ozone Filter (Life Limit)
    Two other itmes were listed as Near Life Limit:
    Imaging Transfer Belt Unit
    Fuser unit
    These are listed consumer replaceable parts, so I ordered them. We received in all of the parts except the Imaging transfer Belt Unit and promptly replaced the three items. The copier still shows the Transfer Roller and Paper Dust Remover/Ozone Filter as Life Limit. The Fuser Unit shows as Ready. The Imaging Transfer Belt Unit still shows as Near Life limit, it should arrive shortly.
    How do I make the copier recognize that the Paper Dust Filter/Ozone Filter and the Transfer Roller have been replaced. Is there a reset switch or command?
    How hard is the Imaging Transfer Belt Unit to replace?
    Thanks,
    Steve
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • mascan42
      • Oct 2008
      • 484
      The paper dust remover & transfer roller have counters that must be manually reset. You can only access the counters through the service mode. The transfer belt is fairly delicate and isn't a customer replaceable item.
      • sbarnette
        So how do I get the machine into service mode?
        Steve
        • sbarnette
          Sucess, back up and running.
          I found the sequence I needed to get into tech/service mode and reset the two counters. The machine is back up and running so life is good once again.
          Steve
          • Paul
            8031 life limit
            Steve,
            What steps did you take to reset the ozone filter life limit indicator in service mode...how do you get into service mode?
            Fuser unit
            Thanks,
            Steve
            • sbarnette
              Paul:
              There is a sequence of key presses. I have the list at work. I'll get it to you in the morning.
              Steve
