Bizhub 500 w/ FS510 Finisher; false 10 jams in finisher?
  • xeroid
    Document Technologies Pro
    • 148
    I removed the left end slider cover and inspected sensors. Lots of widgets. manually worked them all. After reassembly it worked until I tested stapled sets and went back to unclearable 10 missfeeds. Any ideas or help with a SM would be greatly appreciated.
  • MR CLEAN OC
    there are two one way needle bearing gears in the gear cluster just before the exit front side clean them. also hole punch clutch clean or replace
    • xeroid
      • 148
      Thanks Mr Clean, They looked ok but I took apart cleaned reassembled and can't get to act up again.
