Yellow Background bizhub c252
  • alfpanasonic
    • Jan 2007
    • 73
    I have a bizhub c252 that make yellow copies (background) every cycle of copies. The original have all colors possible.
    In test print, in gradation adjust is the same.
    Any idea?
  • ebm
    • Apr 2007
    • 183
    Does the image show wavy lines along with the background? Had a machine with a wavy magenta background pattern. Needed to replace the HV1 assembly to repair. Hope this helps.
    • alfpanasonic
      • Jan 2007
      • 73
      No, is a solid yellow background.
      I'm going to chech HV1.
      • alfpanasonic
        • Jan 2007
        • 73
        solved
        it's laser yellow
        Thank's everyone
        • Scott_Lewis
          • Mar 2007
          • 519
          Originally posted by alfpanasonic
          it's laser yellow
          Thank's everyone
          Thanks for letting us know what the solution was.
          Are you saying the write unit caused this somehow?
          • alfpanasonic
            • Jan 2007
            • 73
            laser
            Yes
            I change the laser yellow with the magenta and the background yellow change to magenta.
            In this moment I'm waiting for the laser unit (4 laser, because i must change all the lasers
            • alfpanasonic
              • Jan 2007
              • 73
              Laser ok
              Today (27/6/2007) we change laser's and was everything ok
              • TonerMonkey
                • Jun 2005
                • 71
                Bit late.................
                A bit late on this one but I've had this before - sorry Alf I'll try and be quicker next time !!!!!!
                • Bizhub
                  • 147
                  I would only fit one write unit and keep the other three for spares.
                  Dont replace all four like KM recommend, you just don't need to.
                  • Juggy
                    Technical Support
                    • Sep 2007
                    • 101
                    I did face the same problem. The machine will produce all the colors properly with Full edge to edge Yellow background. The problem was PWB-A. Try and swop the PWB-A with a working machine and isolate the problem. Good luck
                    • alfpanasonic
                      • Jan 2007
                      • 73
                      This problem is solved?
                      Anything else?
