C6500
random
Perhaps EVERY machine was a bit strong
You saying that every machine you have is doing this?
How many machines do you have?
Fuser rebuild fixes? what do you replace and how long till it comes back?
Have you checked the one way drive gears?
Is it only on black?
Is it exactly the same each copy?
Does it do it on normal stock?
Is it plain bonded 300gsm stock you doing?
Hey random if the color on the right hand side is the color through out the page is the right hand side the lead edge? what color is it suppose to be? did you run test pattern 53 at 130 and 40 for all colors does it produce similar results as your sample?
Phew, that was exhausting!!Comment
AusiTech
Wow Random, looks like you're in Sh$t.
I have a few of these machines out there. I have run off literally hundreds of halftones but have never seen it. And I'm sure the customer would have picked it too.
It just doesn't make sense that when you replace the belt it fixes it? i mean what does the belt do except turn around.... Could it be heat issue?
It hard to tell unless you look at the original.
Could you be getting voltage drop? Still doesn't make sense.
All i can suggest is maybe check more into the fuser drive.
Hang on... do you work for a dealer? if yes then where do you get you're fuser belts from? are they KM original parts? and one last question, how many copies has it done?Comment
trapps
I have seen this problem just yesterday, but more obvious on 300g stock.If i run a halftone 100 on magenta/cyan you see it, however on 80g stock not so pronounced.Did a test in showroom m/c exact same problem, just to a lesser extent.Lines are in same area on both cyan/magenta.Comment
random
Damn
When you try to repair it you will find sticky residue on the upper roller, this is the reason why as far as I am concerned the problem exists. The belt sticks to this roller where it should slip hence the smooth surface. You may not have to replace the belt if you can clean the residue from the inside.Comment
mecanico
Transfer shifts with halftone on thick paper under high humidity
Hi. with the information i have write down, i have resolved several seemed problems.
[Symptom] Under high humidity environment (70%Rh and over) and when thick paper is used, density change appears on halftone at 2 points (at 225mm and at 380 mm from leading edge).
[Probable cause]
Separation DC current is improper.
[Solution]1) With dipswitch setting, enable process adjustment for each tray. Service mode=> [03 System setting] => [01 Software SW Setting] : Change 01-0 from 0 to 1.
2) For each tray, process adjustment, set the [Separation DC (Front)] and [Separation DC (Back) optimum value within -20 to -30 so that the density difference is the least visible.
