connection in Di 470 using fiery Pi5500
  • remielee
    Technical Analyst
    • Mar 2010
    • 140
    hello guys can somebody help me on how to connect my machine DI 470 or DI 450 in fiery PI 5500 cause it said on the guide manual that i downloaded only windows 98 up to nt the OS that i can be use, but i need the windows XP, PLEASE! PLEASE! guys i need your help and sir/mam if you have an instruction much better and it would be great helpfull to me. thank you very much in advance....wait for all your reply guys!!!
  • RRodgers
    • Jun 2009
    • 1947
    IF you look in network neighborhood do you see it listed?
    You can also install it using the generic PS or PCL driver (HP LJ 4)
    • TheOwl
      • Nov 2008
      • 1732
      The drivers are available from the Konica Minolta website (well the Australian one for sure). You should download and install those drivers for XP.
      • remielee
        Technical Analyst
        • Mar 2010
        • 140
        it was listed, actually heres the story i connect the fiery Pi5500 to the copier di 470 and then from my laptop to the fiery Pi5500 connection using cross cable then set up ip address, driver,ping etc. after that when i print nothing happend the ip address is right coz when i ping it it replys to my laptop. my be the driver not supported the xp os?what do u think guys?
        • remielee
          Technical Analyst
          • Mar 2010
          • 140
          thanx, but i tried to find in konica website but only bizhub was there? anyway i will try again
          • Hansoon
            • Sep 2007
            • 3349
            Search for Pi5500 NOT Di470.
            Hans
            “ Sent from my Intel 80286 using MS-DOS 2.0
            https://www.copytechnet.com/images/smilies/biggrin.png
            • remielee
              Technical Analyst
              • Mar 2010
              • 140
              Hans
              Ah ic i didnt think about that,thanks a lot ken more power!
              And also to all guys who made a response to my problem thank u all! Mabuhay!
