Konica 8031
  • Showman
    Konica 8031
    I received an error c-0016 indicating a black toner motor problem. I determined the imaging unit was frozen and replaced it. After two printouts, I received the error C-OF37.
    Can anyone help with this?
    Thanks.
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    I doubt it is the imaging unit- you probably have hard packed toner at the bottom of the toner hopper! Vac it out and see how it goes.
    If you are hitting your head up against a wall it always feels better when you stop.
    • AusiTech
      C0F37
      C0F37
      In the manual it relates to cyan but i know it's wrong!! It's actually relating to the black.
      The IU has 4% higher than its target value.
      My guess is you replaced a faulty IU with another faulty one.
      Problem is if you test another one and it doesn't fix it... the chip resets and its dead.
      I recommend shaking IU's by tipping up on ends whilst in bag several times, especially Biz hub colour range.
      There is a reset button under the right hand side door but usually open/close door works for this error.
      • random
        From memory the cyan and black hoppers are driver off the same motor. You can find this behind the cover that the T-Bar clips into. I have had one of these somehow?? being unplugged.
        • AusiTech
          Unplugged
          LOL how the hell that happen
          • random
            I think the cadet got a bit over excited doing the refurb
