hello guys i need your expertise regarding the problem of my 1 BH600 the problem was the sand clock only shows in the screen no KM logo although it initializing fusing are warming up i have change the printer control board,I/O board and even the DCPS but still same problem show, Need your help guys thanks in advance.
BizHub 600
The operation panel displays an hourglass and does not continue to the "Ready to Copy" screen.
Description:
Solution:
PROBABLE CAUSES:
1. The files on the System or the Image CF card are corrupt.
Reinitialize the code on both CF cards. The Image CF card is accessible through the right side of the machine between the two serial connectors (there may be a cover over it). The System CF card is located on the back of the System Board. Follow these steps in order:
- Delete the files on the CF cards. DO NOT FORMAT THE CARDS.
- Obtain the Image Base and system Base files from the Download Selector.
- Expand the base files and copy them onto the corresponding CF cards.
- Flash the firmware to the current level.
Notes:
a. Both cards must be reinitialized at the same time. Doing only one card will not correct the problem.
b. Instead of deleting the files from the CF cards, you may want to cut-and-paste them to a temporary folder and then install the new code. This process seems to be more stable than just deleting the files. Once the files are placed on the CF cards, delete the old files.
2. The System Control CF card was not installed on a newly installed System CB.
Remove the System Control CF card from the back of the original board and install it on the current board.
- System Control Board CF Assembly (p/n 57AE -952 1E)
- System Control Board for a bizhub 750 (p/n 57AA -906 2E)
- System Control Board for a bizhub 600 (p/n 57BA -906 2E)
3. After updating firmware, the system control CF becomes corrupt.NotesCAUTION: The system and image CF cards should never4. Failed Image control board.
Replace the Image control board (p/n 57AA -901 6G) and flash the firmware to the latest version. The latest version firmware or system software is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'. -
Description:
Solution:
PROBABLE CAUSES:
Notes:
Replace the Image control board (p/n 57AA -901 6G) and flash the firmware to the latest version. The latest version firmware or system software is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.Comment
How you all doing guys ? I've got a very similar problem. A 750 popped a "c4707". I didn't go for the laser at 1st. Reason being is that it wouldn't let me into techrep/Srvc mode. Right side of screen empty, while left side only showed meter, word detail & end or exit. S-00-S-01 did nothing. I reset w/Utility for trouble clear & w/Print board button. Reboots into "4707". Been working on minoltas for long time. Was there for the merger. Never had a laser go on me in a minolta or kon/min. Other brands don't act like this w/laser fail. Started w/image board, print & main boards from a "600 though". Before powering up, I put in 750's original CF cards & NVram. That did nothing. Changed laser. Put all original board, cards & NVram. All ok but fuser not coming on. 5min still no code. What do you think ?Comment
bh600/750 cf cards
i always start with a "rebuild" of the 2 cf cards.. cut dont delete the files off of them... then load base firmware, then ver 17, 20 then 30..
also i thought if the drum unit/tgr/cl blade area is packed with toner and soiling the photo sensors there.. that'll cause wierd freezing/ fuser warmup probs... good luck!Comment
Re: BizHub 600
If you KM guys have a utility, we Oce guys would love to know about it.
Thanks in advance,
KComment
Re: BizHub 600
Im having the same problem, does anyone have the firmware they be willing to shareComment
Re: BizHub 600
I have a badluck with Bizhub 600.. 2 Days ago i given my Bizhub 600 in scrapafter just 18,000 copies i printed. It was keep on "Now warming Up" but never beed "Ready to copy"
Tried almost 5-6 High knowledge mechanics but no one was able to solve the issue so given the machine in scrap to release my tensionsComment
Re: BizHub 600
Are you sure they were really high knowledge mechanics? I've seen this many times as have many people here I'm sure. It's never cause for machine disposal - though that is an old machine now anyway.Comment
Re: BizHub 600
Changed 2 times PRCBComment
