scan to pc(smb),c200
  • sairam
    • May 2009
    • 26
    hi,
    how can i scan to pc,i add all in puts to entry what m/c wants to scan. but no result.can u send any body c200,firmware .
  • RRodgers
    • Jun 2009
    • 1950
    Be sure your paths are correct, also be sure username and passwords are correct as well. They are case sensitive.
    • sairam
      • May 2009
      • 26
      plz tell me the procedure
      • bizhub1
        • Sep 2008
        • 230
        You need to enter the IP address of the pc your going to scan to and the filepath which is the folder you want the scanned images to go to. On this model you have to have the latest firmware to scan to smb.
        • sairam
          • May 2009
          • 26
          plz send any body c200 firmware
          • sairam
            • May 2009
            • 26
            I have solved above problem with u r suggetion .thank u very much sir.
