Bizhub c-451 / Fiery Ic-409 Problems
  • pol
    • 10
    First I would like to apologize if the text is bad, but I am using a translator.
    Working with a bizhub c-451 in a graphic in Brazil and am having problems printing pdf using the Fiery IC-409. Every time the Fiery loses the connection to the PC and restarts when I try to print that file type.
    Today I can only print the file. PS (Postscript)
    I believe that the problem might be the upgrade paths, but I have no copy of the system to reinstall.
    Today I use the Command WorkStation 5.1.
    Another problem I have is that whenever the printer enters power saving mode, it loses the connection to the Fiery.
    I tried requesting the latest firmware for the Konica, but their support here in Brazil is very bad.
    I would be very grateful if someone can help me.
  • kmcopier
    PSP
    • 183
    what is your version of system software? and what patches are installed? gr kmcopier
    • pol
      • 10
      Fiery EFI - Version 8e - 50_45-KM - V 1.01 - Ram 171,00 MB
      Patches: 1-V1JNZ - 1-WA4ZQ - 1-W5C85 - 1-UIG65 - X4RRR - 1-XRGJ7
      Firmware C451 - "R5"
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        There was about 3 patches for the power save issue. Which version of adobe reader are you using. If it is V8 either update to V9 or downgrade to v7. V8 had a lot of printing issues with it. most were fixed with patches but not all.
        • RRodgers
          • Jun 2009
          • 1947
          As mentioned above I'm pretty sure I remember seeing a patch for this.
          • pol
            • 10
            I'm using version 8, but I use Corel or Photoshop to generate the pdf with standard X1A.
            Before I had no problem to print this file type.
            The problems started after the latest firmware update the printer or after updates Patches, can not remember for sure.
            What is the latest firmware version available?
            Is there any possibility to uninstall the patches of fiery?
            • pol
              • 10
              Help me ! )
              • pol
                • 10
                Please help me ...
                • pol
                  • 10
                  • RRodgers
                    • Jun 2009
                    • 1947
                    No, there is not. Usually you have to reinstall to get rid of them.
                    • pol
                      • 10
                      unfortunately I do not have the reinstallation cd, is downloading?
                      About the version of c-451, firmware "R5" is the latest version?
                      thanks for replying
                      • pol
                        • 10
                        thanks for replying
                        any help?
